Am I right in thinking that episoidal headlight units are the same on a left and right hand drive car?
If that is the case is there any reason why I can't adjust the beam with a screwdriver, rather than sticking horrible beam adjusters on when driving in Europe.
Episoidal beam adjust for European driving
FEP
Morat
no reason. You loosen the three screws on the back of the dip beam headlight and rotate to the other end of the slots.
gareth
You sure can adjust them
on the back of the dipped beam units there will be three crosshead screws. Loosen these (they don't come right out), pull the back of the light rearwards and twist it to tilt the beam pattern from RHD to LHD settings, then re-tighten
I usually do this while waiting for the ferry
gareth
Beaten to it!
Morat
Too slow ginger ninja!!
FEP
5 minutes for two replies. This site's just not what it used to be
Muchos gracias chaps.
There's a plastic tab in one of the slots that requires you to almost fully undo the three screws to be able to pull the light unit back far enough to clear this tab.
If you're going to do this regularly, then it's worth taking the lights out and trimming this tab down to almost nothing.
Must remember to change mine back soon - only been back six weeks!
- **BANNED**
The three screws are 'captive',so you cannot lose them!
Your only problem is finding them,but practice helps.I usually end up taking the grilles off and pulling the light units out,I get odd looks on the quayside....
Youth is wasted on the young.
Screws are captive, but some aren't that easy to get a screwdriver onto, especially if you have ABS and/or intensive wash. Removing most of the tab means that you only need to unscrew them one turn each, instead of about six.
gareth
Neat tip that brian, i'll do that next time i've got access
