Facelift engine to Pre-facelift shell
E30_Crazy
Post Fri Sep 30, 2011 2:15 pm
Was just wondering if I could use the water pump off of my older pre-facelift engine on the facelift engine I'm about to swap in, and if that would make the coolant hoses match up correctly with the pre-face rad.
The biggest thing I'm seeing off hand, is the overflow for the pre-face. The water pump swap would take care of that. And then the hose that runs from the thermostat housing along the passenger side of the block, to the heater core.... Facelift engine hose has a "T" in it, to run to the tank on the passenger wheel well. Can I just swap the non-"T" hose from the pre-facelift into here?
E30_Crazy
Post Sat Oct 08, 2011 5:15 pm
Anyone think this will work? I think I covered all the differences in the cooling systems...
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Oct 08, 2011 5:49 pm
What engine are you working on, to start with?
**BANNED**
Post Sat Oct 08, 2011 5:59 pm
No reason why not,the water pump is the key to the thing,and that will match up to the rest of the system.
Youth is wasted on the young.
E30_Crazy
Post Sat Oct 08, 2011 6:02 pm
Yeah, guess that would help...
It's an M20B25 from a pre-facelift sport, being replaced by a facelift M20B25 (2.7)
I think I've got a hold of a header tank and rad for the facelift engine, so might not have to force the pre-facelift system on the facelift engine.
Grrrmachine
Post Sat Oct 08, 2011 6:12 pm
For M20's, the pumps are interchangeable, so as long as a pre-facelift pump is fitted, you can bolt up the rest of your pre-facelift cooling system to the facelift engine.
http://www.e30zone.net/e30zonewiki/inde ... ater_Pumps
E30_Crazy
Post Sat Oct 08, 2011 6:18 pm
Yeah, I knew about the pumps, I was mainly wondering about the rest of the system. Mainly the hose with the T going to the fl header tank and the heater core (if I can just use the pre-fl one that doesn't go to the fl header tank, just straight back to the heater core)
**BANNED**
Post Sat Oct 08, 2011 6:32 pm
E30_Crazy wrote:Yeah, I knew about the pumps, I was mainly wondering about the rest of the system. Mainly the hose with the T going to the fl header tank and the heater core (if I can just use the pre-fl one that doesn't go to the fl header tank, just straight back to the heater core)
Can see no reason why not,it's a bit like exhaust systems,use one or the other,but they do not 'mix and match'.
Post Sat Oct 08, 2011 6:33 pm
you will need a pre-face pump and it's pipes, IIRC the pre- has 2 outlets on the bottom ?
