i have just started up my 325 after working on it for a while (restoration) and the engine sounds and runs like its off a cylinder, any ideas and how can i check if it is off a cylinder.
new plugs, leads etc and no holes in intake elbow.
also i have bled the clutch but the pedal is going straight to the floor with no resistance, any ideas.
andy
lumpy running and clutch bleeding
andy523
- **BANNED**
Grope the exhaust manifold to find the cold outlet,that's the cylinder that's not playing...could it be an injector sulking?
Clutch...Have you swapped both master and slave cylinders? We seem to find that they fail in pairs.
Youth is wasted on the young.
andy523
will try the manifold idea and the clutch was fine apart from from the master cylinder leaking so it was replaced, should i change the slave just in case, although it was bleeding okay
spbt1
I am no expert but i too had the same running lumpy issue and found that the exhaust valve on no.2 cylinder was not closing properly, after setting the all the tappets the problem went away.
I was also informed that it is always best to change both master and slave cylinder on the clutch and ensure that all the old fluid is removed/flushed out as perished rubber in the fluid will quickly foul the new cylinders.
andy523
no 6 spark plug was the problem, running okay now.
Think i will change the slave cylinder on the clutch, its still the same.
thanks
thanks
