How to stop kangarooing? (jumping when crawling in 1st)
PeteE30Tourer
Post Wed Sep 21, 2011 12:48 pm
Afternoon folks,
I've noticed over the past couple of days getting stuck in road-works traffic that my 325 cab doesn't crawl along in 1st very smoothly - in fact it jumps and lurches along like a kangaroo!
What's the likely cause?
Back behind an M20, but now I can hear it better.
Barx325i
Post Wed Sep 21, 2011 12:52 pm
prop - gearbox coupling generally
asmith88
Post Wed Sep 21, 2011 6:01 pm
i remember seeing someone with this problem cure it with an afm
1990 brilliant red 318 is
Post Wed Sep 21, 2011 6:04 pm
Does it tick over smoothly?
I had a similar problem years ago on my 325, it started hunting at idle and then on constant light throttle it would lurch and kangaroo a bit. Turned out to be the inlet manifold gasket causing an air leak.
Post Wed Sep 21, 2011 7:58 pm
Air leaks and injectors in need of a rebuild.
Also check that the TPS is set correctly.
Barx325i
Post Thu Sep 22, 2011 12:13 am
weird, mine was cured with a new prop guibo but it was definitely more of a mechanical drivetrain lurch issue
PeteE30Tourer
Post Thu Sep 22, 2011 7:59 am
Thanks for the help guys.
Tick-over is fine and steady. I'll look into air-leaks and give the AFM a proper clean too. I was already considering changing the injectors, so I'll go for that too.
Thanks again.
Ajsingh
Post Thu Sep 22, 2011 9:34 am
How would u go about cleaning the AFM?
Without damaging any parts of it
There is a video on youtube showimg how to remove the wiper arm under the black plastic cover and clean the mating surface. It gets clogged with dirt and gives incorrect readings. Most the dirt sits where the car spends most of its revs, i.e mostly driving between idle and 2k will make that part of the track dirty.. Give it a go n clean it...
E30 Crazy!
Post Thu Sep 22, 2011 10:23 am
Do NOT remove the cover of the AFM unless you've proven it faulty by testing it!
If ever "if it ain't broke, don't fix it" applied to anything, it applies to this.
Ajsingh
Post Thu Sep 22, 2011 11:43 am
Brian. What does that video refer to then? Should that NOT be done? I thought it would have helped
E30 Crazy!
PeteE30Tourer
Post Thu Sep 22, 2011 12:33 pm
I have done this in the past (take cover off AFM and clean wiper), but I cant recall it making a difference. The black plastic cover is glued down and sealed as I remember, so you'd have to ensure you re-seal it to stop moisture and dirt getting in and making it worse than when you started. It's a delicate job all round and as Brian said, not worth it unless you really know that's causing a problem. You could easily make things worse if you're not careful.
I dont know if it does any good or not, but I've cleaned my AFM in the past just by squirting loads of carb' cleaner through it and watch all the black deposits disappear.
