323i idle reduction
alexdkj
Post Tue Sep 13, 2011 7:57 pm
Hi guys, im wondering if anyone knows of a way to reduce idle on start up, I know the choke will come in here but with my current exhaust set up it resonates at the 1500 rpm its currently at. Any help?
sweep
Post Tue Sep 13, 2011 8:18 pm
This has a water controled idle valve which are problemaatic,
alexdkj
Post Wed Sep 14, 2011 5:16 pm
Would it be possible to somehow remove the automatic choke???? cause i dont realy need it on start up in this weather! anyone?
kyland
Post Wed Sep 21, 2011 8:06 am
You can adjust the idle from the manifold side of the engine (drivers side on RHD) via the bypass valve...it's the long cylinder attached to the inlet manifold where the vacuum hoses go (for FPR and retard/advance signals). Will try and find a picture for you...hard to describe!
kyland
Post Thu Sep 22, 2011 12:17 am
Here you go...it's no. 5 you're after, and your adjusting no.19. This will reduce/increase idle...but if it continues to be whacky, you will need to replace the air slide valve as mentioned in a n earlier post.
Andyboy
Alpina Colada
Post Thu Sep 22, 2011 10:12 am
They're a bit of a pain these. It can also be down to the ignition being over advanced - you need to check the vacuum advance on manuals and on really early ones (Y/A/B reg), vacuum retard as well. Very often the only way to get the idle down - even when everything seems okay - is to sleeve the air pipe going into the idle valve to reduce the air flow. I had to do this on a 320i which had a new idle valve and everything was as it should be - just could not get it below 1000 rpm.
