What radiator couuld I use with Cosworth YB?
MurphyE30
Post Mon Sep 12, 2011 6:25 pm
As some of you know i'm fitting a Saph cossie engine in my coupe
From the info I have been given it looks like to fit the cossie radiator the chasis legs have to have slots cut out for the radiator due to the width.
I would prefer not to be cutting into the car and use a different radiator which will be suitable to run with the cossie set up and fit without the need to chop.
Anyone have any ideas on what to look at?
Duke137
Post Mon Sep 12, 2011 6:29 pm
Could you not use an E36 rad? They are pretty tight in the bay and can be fitted easily? Just need to pipe it in then dude
Post Mon Sep 12, 2011 9:40 pm
S50 rad is the biggest rad you can fit in the bay on the standard mounts, oil cooler clips to the underside of it nicely, ala -
Uber cooling FTW 8)
MurphyE30
Post Mon Sep 12, 2011 9:43 pm
is the oil cooler the same as the ones used on the m20 Dan or is it from the S50 also?
You get my text regarding payment?
Post Mon Sep 12, 2011 10:01 pm
Thats an S50 oil cooler, will pm you now
MurphyE30
Post Mon Sep 12, 2011 10:18 pm
DanThe wrote:Thats an S50 oil cooler, will pm you now
are the S50 rads and oil coolers easy to pick up?
do you know if the S50 rad,cooler,fan be easy enough to set up with the YB?
Post Mon Sep 12, 2011 10:21 pm
Its basically the same layout as an M20 rad, separate header tank
cecotto_singh
Post Fri Sep 16, 2011 10:15 pm
i had rad and intercooler custom made for mine.
also seen notches cut out of the chassis legs too so the cossie rad and intercooler fit.
MurphyE30
Post Tue Sep 20, 2011 12:28 pm
cecotto_singh wrote:i had rad and intercooler custom made for mine.
Yeah I have pics of fuzzy's engine bay set up with the notches in the chassis legs, I have the cossie rad and intercooler but the intercooler is an Rs500 one so quite big compared to the standard Rwd intercooler
Any pics of yours? Did you keep the hydraulic clutch system or go with the cossie system?
fuzzy
He who sleeps with "Gingers"
Post Sat Nov 05, 2011 7:06 pm
yep, my chassis legs were cut and welded with the standard cosworth rad ,cooler and twin fan set up. it wouldnt have been they way id have done it myself but thats specialists for you.
next step was a custom rad and cooler as there was a lot of space available.
at the time my plans were a big rad in the normal position and a custom cooler possibly in front in the space behind the grill. never got around to it though.
i had lots of problems in my previous cosworth conversion when i used the cosworth cable clutch set up so avoided it this time and kept the e30 hydraulic system, the guy done a rough job but it worked well.
it also makes lighter work of gear changes when using heavier duty clutches.
