4 or 6 line brake line?
redcar
Post Sun Sep 04, 2011 5:02 pm
Hi guys, got an m40 316i e30.
Putting a full 325i braking setup (discs, calipers, master cylinder and trailing arm)
I am also looking to replace all the oem brake line with uprated braided brake line, however i see that there are 4 line and 6 line brake lines.
Which one would i need?
Cheers.
ian332isport
Post Sun Sep 04, 2011 5:12 pm
If you have rear drums then you need a 4 line kit. If you have rear discs, you need the 6 line kit.
Seeing as you are fitting rear discs, you will need the 6 line kit.
Ian.
redcar
Post Sun Sep 04, 2011 5:14 pm
that clears things up, yes, i'll be fitting rear discs.
So i shall order the six line kit.
Cheers :)
Post Sun Sep 04, 2011 6:25 pm
If you're buying Goodrigde braided hoses there are 2 further options - zinc plated fittings ( which will dull over time but are cheaper ) or Stainless fittings ( which are more expensive but won't go dull ).
nickphine
Post Sun Sep 04, 2011 7:48 pm
I have a brand new zinc plated 6 line kit sitting on my shelf, £70 delivered to uk if you're interested. Cheers, nick hine.
redcar
Post Mon Sep 05, 2011 7:23 pm
thanks nick but just got one yesterday for 60. Sorry :)
rix313
Post Wed Sep 07, 2011 10:18 pm
capri_rob wrote:If you're buying Goodrigde braided hoses there are 2 further options - zinc plated fittings ( which will rust over time but are cheaper ) or Stainless fittings ( which are more expensive but won't go rust).
:thumb:
