Rev Counter
turkeysneck
Post Thu Sep 01, 2011 7:59 pm
Can the rev counter be removed without replacing the whole set of guages.
Can anyone suggest someone who can repair rev counters, mine is jerking up and down rather than a smooth fluid like action.
bpowell555
Post Sat Sep 03, 2011 1:09 am
Same, removing the clocks is easy enough, not sure beyond that. If you can get a spare set then you could take em apart and check for wear? I've also got a random fuel guage so will tighten the brass nut and see if that helps the revs. Can't hurt and so far the tach is only every so often whereas the fuel guage is all the time and a pita,
http://www.e30zone.net/modules.php?name ... ove+clocks
1990 325i touring
She's a minter! Best 3 years of my life - bye bye baby :D
Post Sat Sep 03, 2011 10:16 am
All the gauges are easily replaced individually, but bear in mind that the electronics that drive all the gauges, except for the speedo, is all contained on the SI board in the front half of the case.
The needle of the tacho is driven by gears, and a small piece of grit in the teeth can cause this gauge to stick.
beema_boy
Post Sat Sep 03, 2011 7:35 pm
Easier to just replace the cluster to be honest. Although it is easy enough to take apart and if your good with electrics then it shouldnt be a problem. Im not the best so once the cluster was apart i tried not to mess too much
Please visit our new store at:
www.phillyskate.co.uk
PM or email for FREE Phillyskate stickers through phillyskatestore@googlemail.com
