Bad vibrations
Cloggy Saint
My touring has an extremely annoying vibration that I need to sort out. It's quite a harsh vibration that seems to affect the whole car but I especially feel it through the pedals and floor pan and it tends to be worse when accelerating in 5th from low revs. Over the last couple of years I've replaced all suspension parts/bushes etc but I've never done the engine or gearbox mounts or the prop' centre bearing. I know it's a bit vague but can anyone offer some suggestions?
threelander
did you replace the donut between gear box and prop it sounds like a problem i had and this was the culprit
Green
Gearbox mounts when they're gone usually cause a clunk when changing gear, sounds like it could be the prop donut or other moving part.
Cloggy Saint
Thanks for that, I guess I'll be starting with the donut, which part is it?
http://www.realoem.com/bmw/showparts.do ... 10&lang=en
Grrrmachine
- E30 Zone Wiki / Team Member
Unsurprisingly, it's the most expensive part on that list: 26111225624
Cloggy Saint
Grrrmachine
threelander
nice one that grrrr
i let a garage do mine first time and they put all the bolts in the same way the tossers so ended up doing it again myself 12 months later.so the answer to your question is no it,s not a difficult job at all if all the bolts are facing the right way mate.i,m sure you will be ok but i would fit new prop centre bearing at same time cloggy
Cloggy Saint
