oil level indicator
martijn76
Post Fri Jul 22, 2011 3:49 pm
Everything else is working ok, only the oil level light is always burning (I checked the oil level of course ..)
Is this normal when using a m30 sender, or should it just work properly?
Bristol_Jer
Post Sat Jul 23, 2011 9:24 pm
Maybe a faulty sender? Not sure how you'd test it though
leeparkes
Post Sun Jul 24, 2011 2:06 pm
It should just work normally.
martijn76
Post Sun Jul 24, 2011 2:52 pm
I thought it could be like with the temperature sender, different wiring in the vfl
