Everything else is working ok, only the oil level light is always burning (I checked the oil level of course ..)
Is this normal when using a m30 sender, or should it just work properly?
oil level indicator
Bristol_Jer
Maybe a faulty sender? Not sure how you'd test it though
leeparkes
It should just work normally.
martijn76
I thought it could be like with the temperature sender, different wiring in the vfl
