everytime it rains my car doors wont open!!!!
blacksoul
Post Thu Oct 20, 2005 12:45 am
hi guys ok here goes. when i bought my cabby the last owner had the car compleatly delocked. so it just opens off the alarm fob. and that works fine. but!! over the last few weeks when we have rain and the car has been sitting on the drive, it does not open off the fob, only after a few hours. its clearly rain getting in there to do this but what could be the cure and also has this happened to anyone else. im realy thinking of getting 2 new doors and a new bootlid. thanx b.
Batch
Post Thu Oct 20, 2005 6:36 am
If the problem appears in both doors and boot at one time then the problem should be found in the central control unit - it's getting wet. Find where it is located and make sure it remains dry in any wather cinditions.
mrLEE30
Post Thu Oct 20, 2005 6:58 am
yeah like Batch says, or even easier move your car and life to a country where it doesn't rain!!!! :cool:
mrlee
Post Thu Oct 20, 2005 9:20 am
Central locking ECU is inside the cill under the driver's side footwell speaker. Right near where the sunroof drains end.
If the drain slots in the cills aren't clear then it will waterlog.
tourer-dan
Post Thu Oct 20, 2005 1:19 pm
Is it the central locking which isn't working, or the door opening system?
m-dtech
Unapproved Trader caution
Post Thu Oct 20, 2005 1:40 pm
mabey the car does not want its feet wet ? :mad:
Karan
Post Thu Oct 20, 2005 4:32 pm
try the white connector where the loom from the doors enters the car on the drivers side
doug325i
Post Thu Oct 20, 2005 5:21 pm
Least you can sell it with "Dry miles only" :)
blacksoul
Post Fri Oct 21, 2005 11:45 pm
hey thanx guys some helpfull &funny advice there:). well its a convertible so it does not have the gutters, but the rain is getting in someplace. its not the alarm at fault. it just seems like the door catches are siezing up in the rain. i will have a good inspection this weekend weather permitting and of course if i can in the car lol. thanx again b.
craigieeb
Post Sat Oct 22, 2005 2:16 am
im going with karan on this one, i had a simaler sort of problm, and it turned out to be water getting to the ruber shiefe that goes from the door to the pillar
check out the guide it gives you a step by step
http://www.e30zone.co.uk/modules.php?na ... ocking.htm
Batch
Post Sat Oct 22, 2005 8:35 am
blacksoul wrote:hey thanx guys some helpfull &funny advice there:). well its a convertible so it does not have the gutters, but the rain is getting in someplace. its not the alarm at fault. it just seems like the door catches are siezing up in the rain. i will have a good inspection this weekend weather permitting and of course if i can in the car lol. thanx again b.
If the door resizes in the wet then the only conclusion is that you have wooden doors :mrgreen: because metal or rubber shouldn't change its size in the effect of humidity winkeye
rayman
Post Sat Oct 22, 2005 10:20 am
the most coming problem is water in the wiring plug on the a post. pull the rubber boot off, squees 2 plastick lugs together & pull, the connector should seperate. wash out connector pins with wd40 &clean any green corosion of the pins. if any of the pins snap.you will have to solder new wire in & bypass the pins. the wire can be threaded through a hole in the plastic wirring conector. (check bothe doors) if door wirring is o. k. check relay. under o.s. front speaker.remove speaker, remove2 screws under speaker,remove plastick cover for relayin hole under speaker,(if still there) remove relay & check for water ingress.
if your not living on the edge, your taking up to much space.
blacksoul
Post Sat Oct 22, 2005 10:52 pm
cheers guys some great info there very greatfull. b.
