everytime it rains my car doors wont open!!!!
blacksoul
hi guys ok here goes. when i bought my cabby the last owner had the car compleatly delocked. so it just opens off the alarm fob. and that works fine. but!! over the last few weeks when we have rain and the car has been sitting on the drive, it does not open off the fob, only after a few hours. its clearly rain getting in there to do this but what could be the cure and also has this happened to anyone else. im realy thinking of getting 2 new doors and a new bootlid. thanx b.
Batch
If the problem appears in both doors and boot at one time then the problem should be found in the central control unit - it's getting wet. Find where it is located and make sure it remains dry in any wather cinditions.
mrLEE30
yeah like Batch says, or even easier move your car and life to a country where it doesn't rain!!!!
mrlee
mrlee
Central locking ECU is inside the cill under the driver's side footwell speaker. Right near where the sunroof drains end.
If the drain slots in the cills aren't clear then it will waterlog.
tourer-dan
Is it the central locking which isn't working, or the door opening system?
m-dtech
- Unapproved Trader caution
mabey the car does not want its feet wet ?
Karan
try the white connector where the loom from the doors enters the car on the drivers side
doug325i
Least you can sell it with "Dry miles only"
blacksoul
hey thanx guys some helpfull &funny advice there:). well its a convertible so it does not have the gutters, but the rain is getting in someplace. its not the alarm at fault. it just seems like the door catches are siezing up in the rain. i will have a good inspection this weekend weather permitting and of course if i can in the car lol. thanx again b.
craigieeb
im going with karan on this one, i had a simaler sort of problm, and it turned out to be water getting to the ruber shiefe that goes from the door to the pillar
check out the guide it gives you a step by step
http://www.e30zone.co.uk/modules.php?na ... ocking.htm
M50 Turbo!!!
I shall say no more
Batch
If the door resizes in the wet then the only conclusion is that you have wooden doorsblacksoul wrote:hey thanx guys some helpfull &funny advice there:). well its a convertible so it does not have the gutters, but the rain is getting in someplace. its not the alarm at fault. it just seems like the door catches are siezing up in the rain. i will have a good inspection this weekend weather permitting and of course if i can in the car lol. thanx again b.
rayman
the most coming problem is water in the wiring plug on the a post. pull the rubber boot off, squees 2 plastick lugs together & pull, the connector should seperate. wash out connector pins with wd40 &clean any green corosion of the pins. if any of the pins snap.you will have to solder new wire in & bypass the pins. the wire can be threaded through a hole in the plastic wirring conector. (check bothe doors) if door wirring is o. k. check relay. under o.s. front speaker.remove speaker, remove2 screws under speaker,remove plastick cover for relayin hole under speaker,(if still there) remove relay & check for water ingress.
if your not living on the edge, your taking up to much space.
blacksoul
cheers guys some great info there very greatfull. b.
