Oh god it's gone to pot. Loom is melting!!!! Wiring related
TheChin
Post Sat Jul 09, 2011 6:14 pm
Just changed the loom over as the old one was all exposed! Just about to start and I saw smoke and found the wire.
The new one I made was continuity tested and all wires checked. It seems to me it might be connected to an earth instead of live. It's a thick red wire with thin blue line. It comes from the pin connector on the passenger side to a block and back up to the ecu.
There are new plugs on the new loom that cannot be used, that to do with anything?
Here are some pictures of the offending wire. Please help me I can't drive it
TheChin
4 Door E30 325i, JOM Coilovers, OG Axis Wheels
Post Sat Jul 09, 2011 6:17 pm
What loom have you changed, and in what???
TheChin
Post Sat Jul 09, 2011 6:40 pm
Sorry engine side loom, 325i Se 1987
TheChin
**BANNED**
At a rough guess,Brian,some-one has not seen this;
http://www.e30zone.net/modules.php?name ... ic&t=83367
Youth is wasted on the young.
Post Sat Jul 09, 2011 6:46 pm
That's what I was thinking!
TheChin
Post Sat Jul 09, 2011 7:08 pm
I've had a read through and will have a look. Shame i couldn't have seen it earlier. So fix this then it's sorted
TheChin
**BANNED**
Post Sat Jul 09, 2011 7:16 pm
TheChin wrote:I've had a read through and will have a look. Shame i couldn't have seen it earlier. So fix this then it's sorted
I tend to learn by my mistakes as well.
If you isolate the wire as described in that link,and repair the damage to the loom,you should be OK.
TheChin
Post Sat Jul 09, 2011 7:20 pm
Fantastic, thank god for the zone!
TheChin
Post Mon Jul 11, 2011 11:00 am
Depends how much damage has occurred. The worst potential damage is to the other wires that are in contact with the brown wire where it goes down through the duct to behind the glovebox.
Once the brown wire reaches here, it is joined to a much larger brown wire which won't have been damaged by the excess current.
You will have been left with a foot length or so of thin brown earthed wire going down through this duct which will have been badly burnt, and melted itself into the insulation of random wires that are in contact with it.
The engine loom damage is fairly easy to check along its length, but there's no easy way of checking on what's happened inside the duct.
TheChin
Post Mon Jul 11, 2011 11:11 am
The dash is out at the moment; will that enable me to get access?
I may see if i can bridge a wire to skip it all out. I just hope it all works!
Any idea why I have extra plugs on the loom?
TheChin
TheChin
Post Mon Jul 11, 2011 2:15 pm
Can i just check. I am being rather thick today.
Brianmoore has stated:
Check whether there is any wire connected to pin 20 on the car loom side of the connector. If there is, it will either be red/yellow or brown.
If it is brown, cut it away from the pin, and make sure the free end can't come into contact with anything.
If it is red/yellow, then leave it alone - it's the power feed for the ABS system. You will then have to check pin 20 of the engine loom side of the connector, to see if it has a red/yellow as well. If it has, all well and good, but if there is no red/yellow fitted, you will have to add one, between the pin and the terminal of the DME relay that has a red/blue on it.
By car loom connector I'm guessing you are talking about the ECU?
And the car side loom would be the round pin connector that is attached to the bulkhead?
On the round pin; there is the red/yellow pin as that's what in the picture as melted.
So i just need to check the ECU to see if there is a brown wire; if there is remove that and make sure it doesn't touch anything? Then that's done.
Really not getting this, and no idea why :( Lack of sleep I think.
TheChin
TheChin
Post Mon Jul 11, 2011 6:39 pm
Woop all done but now it's not starting? The starter motor is spinning around but that's it
TheChin
The "connector" is the C101 20 pin plug and socket next to the fusebox, where the engine loom plugs into the body loom.
The red/yellow connects to pin 20 on the engine loom side, and is the power feed for a later ABS system.
The brown wire is connected to pin 20 on the body side, and is a left over from when E30s were fitted with two wire brown temperature sensors.
The red/yellow has 12 volts on it when the ignition is switched on, and the brown wire is an earth. This is not good.
