Can i just check. I am being rather thick today.
Brianmoore has stated:
Check whether there is any wire connected to pin 20 on the car loom side of the connector. If there is, it will either be red/yellow or brown.
If it is brown, cut it away from the pin, and make sure the free end can't come into contact with anything.
If it is red/yellow, then leave it alone - it's the power feed for the ABS system. You will then have to check pin 20 of the engine loom side of the connector, to see if it has a red/yellow as well. If it has, all well and good, but if there is no red/yellow fitted, you will have to add one, between the pin and the terminal of the DME relay that has a red/blue on it.
By car loom connector I'm guessing you are talking about the ECU?
And the car side loom would be the round pin connector that is attached to the bulkhead?
On the round pin; there is the red/yellow pin as that's what in the picture as melted.
So i just need to check the ECU to see if there is a brown wire; if there is remove that and make sure it doesn't touch anything? Then that's done.
Really not getting this, and no idea why
Lack of sleep I think.
