can anyone tell me how to test if my tps is working fully there is a faint click just as the tb starts to move but nothing else as you move it further how can i check of its working at full throttle (wot)
any advice much appreciated.
testing tps
e30-320i
89 325i touring
buster
it only clicks once.Basically before it clicks the engine knows its at idle,after it clicks it knows its at throttle,thats it.Its not like a potentiometer (sp?) just Idle,throttle thats all.
e30-320i
so if it clicks its working then
89 325i touring
Andy_magic
In theory, yes.
Best was is to get a multimeter (under a tenner) and check continuity between centre pin and left for idle switch and centre pin and right for WOT. (I think it's that way round)
e30-320i
so when you say "wot" that is just the possition after the click? i think thats where i got confused i thought it could detect wide open throttle to let more fuel in. sorry to sound dumb but i,m no mechanic and it doesnt take alot to confuse me
89 325i touring
Andy_magic
WOT = Wide Open Throttle
WOT actually happens at about 75/80% throttle open, it tells the ECU your nailing the motor.
All the TPS's I have checked don't click when they get to WOT due to the internals of the switch, as long as you have continuity at idling position and WOT it's sorted.
Hope that helps
If you get stuck give me a shout, I'm at Colchester about 35 miles away from you as the E30 flies and know my way round motronic 320i's like the back of my hand
Hope that helps
e30-320i
i knew i'd end up sounding thick
oh well i'm learning and i think i got it now i'll have a look when i get time will i need to change the tb gasket when i re-fit it.
cheers for the advice i'll give you a shout if i get
AGAIN
89 325i touring
Andy_magic
No worries mate, theres so many abbreviations and often variations of the same thing.
Good luck with getting it sussed and don't forget to post up hte results
