My E30 325i Sport Mtech 1
djsimmy
Post Tue Jun 07, 2011 7:55 am
Picked this up at the weekend!
its a bit battered and needs lots of tlc! mostley electrical but it drives sweet as a nut!
and sounds amazing
ill crack out the slr later and do a propa shoot but for now so shit phone pics
Plans,
Replace the back springs because i am 100% they are cut to get it that low! needs 60mm springs on the back.
fix all the electrical issues then treat it to some paint and just enjoy it :D
staley_turbo
Post Tue Jun 07, 2011 8:21 am
Looks smart. Tech 1s do look good low. :cool:
ali50ferrari
Post Tue Jun 07, 2011 8:23 am
this was a zoners wasnt it? i swear there was some pics of it outside a factory unit somewhere, ps welcome to the zone thats a really nice car!
The preacher is pious lord, for he is scared of hell, where as me I sinned freely trusting in your mercy
E30_Crazy
Post Tue Jun 07, 2011 8:54 am
Nice looking Tech1, not all falling apart like most seem to be... Wanna trade?? winkeye
djsimmy
Post Tue Jun 07, 2011 8:58 am
who ever owned it before must have had alot of electrical faults cos where stereo is missing there are wires just cut and left everywhere plastic panel is missing under the dash there is a lose cable hanging under the ecu, some stuff in bay isnt plugged in.
list of work to do
Rev count doesnt work
Mpg guage
Temp guage only goes to 1st notch
Oil level light is on where mirror is
coolant light is on where mirror is
not sure if service indicator stuff works lights up when ignition is on but nowt else when driving
right headlight doesnt work
right full beam doesnt work (left one is missing has air duct)
front fogs dont work
heater only works on number 4
on board computer to the left of the radio doesnt work..
oil leak from the top rocker cover
change the rear springs
Cook318IS
Post Tue Jun 07, 2011 9:03 am
Looks like you've got your work cut out then! It does loook nice though! I'm looking forward to seeing the proper 'shoot :)
Post Tue Jun 07, 2011 9:05 am
Rev counter/MPG - check fuses first
Temp gauge - may have the "thermostat delete" option :eek:
Is there oil in it ? Is the wire connected to the sender
Is there coolant in it ? Is the wire connected to the sender on the expansion tank - these senders are a common failure and can be bought cheaply from GSF but there are 2 sizes so take the old one with you.
Lights - check bulbs, fuses and relays first
Front fogs - check bulbs
Heater may need a new resistor pack ( Common failure ) or may just need freeing off - access through panel in engine bay, remove the blower motor and oil the bearings.
OBC may need backlight bulb ( common failure )
Rocker cover gasket about £15 from dealer
All fairly common but fairly easy stuff to fix.
If you're gonna keep it that low you might want to make a sump-guard your first purchase before you do anything else.
Nice looking car 8)
djsimmy
Post Tue Jun 07, 2011 9:25 am
cheers for the info mate!
i was hoping it was just all normal issues.
ill be leaving the front that low yeah. im used to having crazy low cars and never broke a sump yet! so ill just be carfull lol i had a polo with tt engine sump was crazy low on that lol.
after some 60mm rear springs if anybody has got some.
yeah coolant is full and so is the oil...the wires seem to be plugged in but where the coolant plug joins the loom seems a bit wierd some wires not plugged in etc.
pony
Post Tue Jun 07, 2011 5:06 pm
Welcome.
What springs and shock absorbers are on that?
It looks pretty low nearly obscenely.
First thing you want to get it throughly checked over and a good service Inspection I/II (if the cambelt and water pump not been recently changed).
PS
I own a Tech1 too.
Bela
Post Tue Jun 07, 2011 5:29 pm
Black Beauty... :D
What wheels are on there?
tonybtonyb
Post Tue Jun 07, 2011 9:57 pm
capri_rob wrote:Rev counter/MPG - check fuses first
Nice looking car 8)
I couldn't put it better myself,a lovely looking tech one! :cool:
djsimmy
Post Wed Jun 08, 2011 7:36 am
wheels are lenso bsx (sadly not rs's) 7 by 16 at front and 9 by 16 at back.
pony im not sure i have a recepite here for "apex" springs and shock kit. but ive got a feeling they are spax cos the rear has adjustible dampening.
Its booked in for an inspection at a local bmw specialist on the 17th :D
lyricalnut02
Post Fri Jun 10, 2011 3:06 pm
nice looking tech 1.
325i Sport Tech 1 - R.I.P
E30 addict.
djsimmy
Post Fri Jun 10, 2011 11:49 pm
let the games begin! lol
Post Sat Jun 11, 2011 7:28 am
Bloody hell you didn't hang about ! :D
Get stuck in :cool:
djsimmy
Post Sat Jun 11, 2011 9:24 am
sadly this is not my handywork lol taken it up to my mate to sort the electrics got some new springs on the way and i think exhaust is blowing and by the looks a downpipe bolt has snapped lol top half is missing the bottom half is still there. maybe an excuse for new exhaust system
MurphyE30
Post Mon Jun 13, 2011 9:32 am
very nice Tech I :) looks like you have your work cut out for you but great to see you getting straight into it!
Looks mean low :cool:
im sure theres a thread in the photo section somewhere with a load of nice pics of this by the previous owner
djsimmy
Post Mon Jun 13, 2011 12:15 pm
will be intrested if there is!
djsimmy
Post Mon Jun 13, 2011 12:21 pm
bingo! now lets have a read this could be bad or good
http://www.e30zone.net/modules.php?name ... 86&start=0
djsimmy
Post Thu Jun 16, 2011 11:58 am
well new brakes are on :D alarm is fited.
rocker gasket done
heater resistor done..
so half way there
i think pads where well past there sell by date
new 1
djsimmy
Post Wed Jun 22, 2011 11:24 pm
well things get better then they get worse!!
swapped the rear springs for 50mm 1's its high as fuck :(
so might have to try some 60mm springs :( all though ride is 1000000 times better
massive gear box leak i think thick sticky oil all over the exhaust and prop shaft. guess its coming from the box.
put a new coolant sensor in light didnt go out. but goes out when u test it with multimeter.
changed the batterys in my clocks etc .. but the rev counter + mpg still dont work. grrr
downpipe is blowing its bollox off and car feels well slugish :(
back left rear light is full of water grr cos its cracked!
and i need two new rear cv boots :x :cry:
E30_Crazy
Post Thu Jun 23, 2011 8:07 am
Not the best person on here to be giving advice on wiring, but this is what ran through my mind:
Sensor light might be due to wiring gone bad. The multimeter then makes a good contact, making the light go out.
The rev counter sensor is on the gearbox isn't it? (someone confirm?) The CPS on the front of the engine is just for the motronic IIRC. though I remember being told/reading that RPM is measured off the flywheel. Could take a look at that and see if it is damaged, or just gone bad.
djsimmy
Post Thu Jun 23, 2011 8:39 am
cheers will have another look
si911t
Post Sat Jun 25, 2011 8:37 am
Lovely car - good luck with getting it all right
Coops90
Post Tue Jun 28, 2011 8:49 pm
If this is the one from eBay, bargain! I wanted it too.
Also, did you used to have a blue Mk5 Polo?
Malachite uber alles
djsimmy
Post Wed Jun 29, 2011 8:37 am
Hi coops yeah it was, dunno about bargain its gonna cost best part of a grand + to get it all working!
and yeah i had the polo with the 1.8t in it. pics are in other cars bit on forum
oguz327
Captain Armco
Captain Armco
Post Wed Jun 29, 2011 8:56 am
I love a diamond shwartz Tech 1, I miss mine still!
Mine had a leak at the back of the gear box, rear output seal I think? Its in my current car and been repaired 3 times, still flippin leaks though!
djsimmy
Post Wed Jun 29, 2011 2:33 pm
ah might be same then. doesnt drip into the drive or anything but under the box and exhaust is covered in propa sticky oil
Coops90
Post Wed Jun 29, 2011 4:11 pm
djsimmy wrote:Hi coops yeah it was, dunno about bargain its gonna cost best part of a grand + to get it all working!
Fook, not so much of a bargain then!
Just had a look, i remember the build thread on CP back in the day
djsimmy
Post Wed Jul 27, 2011 1:58 pm
i miss the polo but hoping once e30 is sorted it will scratch the same itch i have
djsimmy
Post Thu Jul 28, 2011 2:15 pm
new pic with higher ride hight at back
E30_Crazy
Post Thu Jul 28, 2011 2:29 pm
Not good with wheels and names myself... But what wheels are those?
Post Thu Jul 28, 2011 8:58 pm
Lenso's staggered.
djsimmy
Post Fri Jul 29, 2011 10:37 am
how come its shrinking the pic lol annoying lol
yeah lenso bsx staggered. basically RM/RS wannabe's
djsimmy
Post Sun Aug 28, 2011 10:26 pm
