Rev counter/MPG - check fuses first
Temp gauge - may have the "thermostat delete" option
Is there oil in it ? Is the wire connected to the sender
Is there coolant in it ? Is the wire connected to the sender on the expansion tank - these senders are a common failure and can be bought cheaply from GSF but there are 2 sizes so take the old one with you.
Lights - check bulbs, fuses and relays first
Front fogs - check bulbs
Heater may need a new resistor pack ( Common failure ) or may just need freeing off - access through panel in engine bay, remove the blower motor and oil the bearings.
OBC may need backlight bulb ( common failure )
Rocker cover gasket about £15 from dealer
All fairly common but fairly easy stuff to fix.
If you're gonna keep it that low you might want to make a sump-guard your first purchase before you do anything else.
Nice looking car
