Hi all
I am coming to the end of my e30 m30 conversion, and i have just the last two things on my list...the prop i have under control but the manifold on the other hand is another story...
My Engine was out of a e32 735, the exhaust manifold closest to the bulkhead clears the steering knuckle but the one closest to front of the engine doesnt..any help would be great...
Cheers jay
Bmw e30 m30 exhaust manifold??
johnl320
I removed it cut the exhaust flange off the end and turned it 90 degrees and welded it back on.
Careful not to sheer an exhaust manifold stud like I did
leeparkes
It should clear without modding, what steering rack you using?
johnl320
I think there are differences between manifold of e32 and e34, mine is from an e32 and deffo needed modding
leeparkes
I know theres a manifold and it looks like a long log style but i thought these were on earlier donks?
bimmer1987
Im using the standard steering rack...i lined up the left hand mani and i know i can work with that but the right one..im sure when i lined it up it sat directly facing that knuckle...the cut and bend 90 sounds like an idea...
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
- E30 Zone Meets/Events Team
I didn't cut or shut mine, I was liucky enough to heat up the flange and turn it 90 degrees
MJJ_ZX6RR
Jay,
My E32 rear manifold had to be cut and shut to fit. I eventually replaced it with a full stainless BTB system, so I could possibly be tempted to let the full E30-M30 Powerflow system go if you fancied an easy route.
It would need to be worth something though, else I'll just keep it in the garage as a backup in case I ever sell the BTB.
Pics below (system nearest the fence) that may help show the manifold.
Martin.
Martin.
Lots of bikes, the odd modern BMW, and now an 88 e30 335i Cab project with E32 running gear
