Im using the M52 fuel rail with M50 inlet and the top cover now sits too high.
Is it a case of chopping the plastic supports and rebonding them on lower?
How have you done it?
M50 fuel rail cover sit lower?
I believe so mate, I just leave it off, stainless fuel lines dont look bad
nickso
- Location: Go do that voodoo that you do so welllllllll!!
i just cut the support bits at the bottom off drilled through the cover and fixed it with a bolt, paint the bolts black and it looks ok.
'88 e30 328i M52 track bint.
Mine went on with no mods and I don't think it looks too high
