e36 328 brakes on a e30?
richlyons
Sun Mar 20, 2011 4:41 pm
do they go?
if they dont can any one recommend a good brake upgrade when putting in a e36 328 engine?
ive herd alfa 4 pots go on but im not sure if im making that up?
Taxin
Sun Mar 20, 2011 5:23 pm
Hi i'm just getting a batch of discs and adapters made they will cost about £180. You can get the E38 Brembo calipers from ebay for £200
BMW E30 Convertible - 2.5
keri-WMS
Sun Mar 20, 2011 6:22 pm
I assume the OP was asking about the E36 calipers left over from the engine's donor car, not E38 4-pots?
E36 stuff doesn't bolt straight onto E30 hubs without messing about with adaptors etc.
The Alfa calipers I've seen while doing upgrades for them have a 100mm C>C on the bolts meaning they won't bolt straight up - but I've not seen every caliper Alfa ever made of course.
As you asked about an upgrade there's always the proven WMS route: http://www.e30zone.net/modules.php?name ... 9&start=24
Standard E30 vented discs are good enough, you can fit the entire E36 leg with some faffing and choice parts
richlyons
Sun Mar 20, 2011 6:40 pm
i think the alfa 4 pots go on mk1 golf based stuff, i know the rear 4 pots from a 944 s2 go on the front of mk2 golf hubs, but all that has nothing to do with a bmw!!!
how hard is it to fit e36 legs? as im in the process of buying all the running gear off a e36.
well it will just be the hubs ill want, i want to go down the coilover route.
i can afford to go with the wms set up, looks nice though 8)
Taxin
Sun Mar 20, 2011 6:45 pm
I would never consider using E36 legs it causes loads of problems. Everyone who done this mod in Germany changed back to normal E30 parts.
Sun Mar 20, 2011 6:59 pm
Do you have E38 Brembos under those alpina reps? I expect its 17 inch wheels or bigger to run them
Taxin
Sun Mar 20, 2011 7:07 pm
The E38 calipers fit under the 17" alpina reps with 10mm spacers. They might fit 16" alloys not tested them yet. I managed to get a pair of E38 Brembo calipers on ebay for £70. So with a bit of luck you could have this setup for £250 :cool:
richlyons
Sun Mar 20, 2011 7:10 pm
I don't want to run 17's really, I waned to go with the 15" vw Sebrings I have kicking about
Sun Mar 20, 2011 7:14 pm
Stick with the E30 brakes then
richlyons
Sun Mar 20, 2011 7:18 pm
325's with some good pads and disks?
Taxin
WMS or 300mm.de are the only ones offering upgrades that fit under 15" at the moment.
keri-WMS
Mon Mar 21, 2011 12:27 pm
Taxin wrote:WMS or 300mm.de are the only ones offering upgrades that fit under 15" at the moment.
True, though the 300mm.de ones need thick wheel spacers that change the offset/handling, the WMS ones keep the wheel where BMW intended (assuming we're talking 15" BBS as used by 95% of 15" people). winkeye
e30_ev0
Tue Mar 22, 2011 7:18 pm
do a 5 lug conversion with e36 m3 front hubs and your sorted,
penton08
Tue Mar 22, 2011 9:29 pm
e30_ev0 wrote:do a 5 lug conversion with e36 m3 front hubs and your sorted,
Yep..... because it just a case of slinging a pair of e36 m3 hubs on :roll: To do the job properly it would be cheaper to buy a set of WMS 4 pots.
richlyons
Tue Mar 22, 2011 9:47 pm
Does the e28 share brakes with the e30?
vokietis
Tue Mar 22, 2011 10:05 pm
richlyons wrote:Does the e28 share brakes with the e30?
e28 calipers ,corrado g60 280mm discs :cool:
richlyons
Tue Mar 22, 2011 10:12 pm
Off which one? M535?
Tue Mar 22, 2011 10:19 pm
DanThe wrote:Stick with the E30 brakes then
nothing wrong with well sorted E30 brakes :D
vokietis
Tue Mar 22, 2011 10:20 pm
yes,i think they are all the same exept 518i,but maybe i am wrong
