Exhaust Question
craigieeb
Post Sat Mar 19, 2011 5:13 pm
Can someone tell me why the down pipe wont fit/bolt up on the manifold,
The down pipe is off a 325i or so i'm told
and the manifold is also off an M20
As you can see the bolts on the manifold are off centre to the holes on the downpipe,
What can be done about this?
wullie325i
CAUTION - unreliable trader!
Post Sat Mar 19, 2011 5:18 pm
manifold and downpipe are from different 325's or 320's early and later ones differ slightly you would need a matching manny or downpipe for either one of yours
Post Sat Mar 19, 2011 6:05 pm
the log is from a f/lift 320i and i was informed on here that it's the same as a f/lift 325i one.
what's that zaust from ?
Post Sat Mar 19, 2011 6:58 pm
is that a two piece system ?
got any better pics of the whole thing ??
craigieeb
Post Sat Mar 19, 2011 7:12 pm
You're right Mick, 320i 325i facelift manifolds are the same,
And the system that I was trying to bolt up to the facelift cab, is a 3 piece scorpion system
So is the downpipe to manifold flange different on a 2 piece system to a 3 piece system??
Post Sat Mar 19, 2011 7:43 pm
my standard down-pipes are not connected together by the flange.
craigieeb
Post Sat Mar 19, 2011 8:32 pm
Cheers for that,
I'm going over to have a look at a couple of manifolds tomorrow and i'll be taking the down pipe with me, to see if i can get one to fit...
