Spigot bearing ???
Danny-C
I have been doing some reading and i cant remember weather i done the spigot bearing in my m52 conversion its been a while now but it doesnt ring a bell
, what would b the consiquence of this please
2 door black leather cards wanted
Front wings new or good seconds
M50 inlet manifold Internal fan heaters/blowers ALL WANTED CASH WAITING
shedrool83
e30-EVN
Which gearbox did you use?
If m40 or m42 box was used an m20 spiggot was needed (12mm hole). M50 spiggots have a 15mm hole!
If an m50 spiggot is used the input shaft will bounce around in the bearing under fast pull offs ect and shorten the life of the gearbox as a result
A 2 door e30 with 8 cylinders, what could be better
Danny-C
Hi i used the original 325 gearbox and a m52 engine it doesnt feel wrong but i honestly cant remember
Nothing noticed when ive driven cars that have had the spigot bearing forgotten about, but I do expect the gearbox bearings to be under a lot more stress in certain situationswillnz wrote:I am pretty sure the wrong one would induce clutch shudder/vibration.
e30-EVN
If you used your m20 325 box you shoud have used an m20 spiggot bearing for the reason above mate (12mm hole), when you do your clutch I'd do it at the same time
randomspeedfreak
does anyone have a part number for this spigot bearing?
do i need a 325 clutch release if im using an m42 box?
cheers
matt
cheers
matt
e30-EVN
general rule is if using e30 box use e30 release bearing.... if using e36 box use e36 bearing
im running an m20 release bearing in my m42 box and its been fine for months..
ask in bmw for an m20 spiggot bearing, i cant find the part number sorry but i just asked for one tbh... 12mm hole
Jimbob
Sorry to drag up an old thread, but I'm beginning to panic..!
I'm fitting my M42 gearbox tomorrow, the M20 clutch and flywheel is already attached to the engine. I haven't changed the spigot bearing - the M52 item is still attached, based on the fact that the M42 also shares a 15mm inner diameter spigot bearing.
Do I really need to fit the M20 (12mm) bearing?
