Sump Gasket
Alpina99
Post Thu Feb 03, 2011 8:56 pm
I've noticed a lot of people talking about only using a genuine sump gasket on M50 conversions,
Apart from the obvious price difference, what else is there that makes everyone recommend genuine over aftermarket ??
Gone, but not forgotten !!
Post Thu Feb 03, 2011 10:17 pm
If the 'other' gasket is a steel type then I dont see what the problem is, the early fibre gasket was changed to a steel/rubber edged gasket, ive never known an early gasket not to leak.
The best advise is to change the gasket before you fit the engine :)
Duke137
Post Fri Feb 04, 2011 8:51 am
DanThe wrote:If the 'other' gasket is a steel type then I dont see what the problem is, the early fibre gasket was changed to a steel/rubber edged gasket, ive never known an early gasket not to leak.
Amen to changing it when engine out, it's near enough in possible when the engine and box are in situe!
I have a Steel one from ECP by the way
Alpina99
Post Fri Feb 04, 2011 3:32 pm
Thanks for the explanation,
(& it will be changed before fitting)
