Are manual and auto radiators on a 1990 316i different?
cgt
Post Tue Jan 18, 2011 9:23 pm
Some say yes, some say no, anyone know the facts?
Post Tue Jan 18, 2011 10:23 pm
They are definitely different, as the auto rad contains a heat exchanger in the LH tank to cool the auto transmission fluid. You can use an auto rad. on a manual, but not the other way around.
320Touring
when i swapped a 316i from auto to manual i needed a new rad.
The auto rad has 2 pipes into the back of the rad for gearbox fluid.
I swapped it for a manual one without it.
You may be able to block the outlets on the auto one.its seperate from the coolant flow through the rad.
cgt
Post Tue Jan 18, 2011 10:24 pm
Thanks Brian, so I need to find an auto one then! :mad:
Post Tue Jan 18, 2011 10:26 pm
cgt wrote:Thanks Brian, so I need to find an auto one then! :mad:
Either that or a manual gearbox!
cgt
Post Tue Jan 18, 2011 11:23 pm
No, definitely sticking with auto for the daily commute!
