Electric window motors
smithy318i
Post Fri Sep 30, 2005 2:33 am
Can i bolt the motors onto the exisitng manual regulators?
or do i need to replace the whole assembly?
Post Fri Sep 30, 2005 9:12 am
Need to fit the whole assembly complete with motors. Easy job.
Treeman612
Post Fri Sep 30, 2005 11:16 am
I've just picked up a drivers door from an 87 320i, and the window glass (manual window) is different to the glass for leccy windows. If your window glass has a cut-out section in the bottom, it wont work with leccy windows. The glass must be flat at the bottom. I think early cars with manual windows have diff. glass to later ones - if your manual window mechanism is a long tubular frame thingy which is a b**ger to get out of the door frame, you've got the early ones. Will need later flat-bottomed glass plus motor assembly, (plus console switches, etc.) in order to convert to leccy windows.
smithy318i
Post Fri Sep 30, 2005 3:31 pm
are the wires already fitted to non electric cars?
(The ones to the switches?)
dazleeds
old skool raver
old skool raver
Post Fri Sep 30, 2005 3:47 pm
smithy my c reg has leccy fronts if you dnt have them gimme a shout
do some swaps??
www.oldskoolfantasy.co.uk
smithy318i
Post Fri Sep 30, 2005 3:49 pm
Daz...PM'd
alan325i
Post Fri Sep 30, 2005 5:33 pm
i got manual rear ones in my car i picked up today so over the weekend will replace them with elecric ones off old car :D
As well as a hell of alot of other jobs that have got to be done :cry:
