Can i bolt the motors onto the exisitng manual regulators?
or do i need to replace the whole assembly?
Electric window motors
smithy318i
Need to fit the whole assembly complete with motors. Easy job.
Treeman612
I've just picked up a drivers door from an 87 320i, and the window glass (manual window) is different to the glass for leccy windows. If your window glass has a cut-out section in the bottom, it wont work with leccy windows. The glass must be flat at the bottom. I think early cars with manual windows have diff. glass to later ones - if your manual window mechanism is a long tubular frame thingy which is a b**ger to get out of the door frame, you've got the early ones. Will need later flat-bottomed glass plus motor assembly, (plus console switches, etc.) in order to convert to leccy windows.
smithy318i
are the wires already fitted to non electric cars?
(The ones to the switches?)
dazleeds
- old skool raver
smithy my c reg has leccy fronts if you dnt have them gimme a shout
do some swaps??
do some swaps??
www.oldskoolfantasy.co.uk
smithy318i
Daz...PM'd
alan325i
i got manual rear ones in my car i picked up today so over the weekend will replace them with elecric ones off old car
As well as a hell of alot of other jobs that have got to be done
