Removing bathroom sealant..
Post Sun Nov 21, 2010 5:53 pm
At some point it seems some tool has used what looks like bathroom sealant to attach a spoiler. After the spoiler was, err, helpfully removed from the boot I am left with a mess.
So basically, are there any methods of removing it from the paintwork? I've tried peeling, but some of it appears to have stuck properly, so that wasn't particularly successful..
beemerbird
Post Sun Nov 21, 2010 10:59 pm
You can buy silicone sealant remover, but I have no idea how good it is. :P
Post Mon Nov 22, 2010 11:23 am
I assume using thinners is not a great idea either..?
I am going to attack the remnants of the blue gunk stuff with compound, but I will be left with the white bathroom sealant still.
Post Mon Nov 22, 2010 12:06 pm
maxfield
Post Mon Nov 22, 2010 12:49 pm
You sure its not Tigerseal? :eek:
Post Mon Nov 22, 2010 1:57 pm
Definitely not Tigerseal luckily.. Or the spoiler wouldn't have come off 8O
maxfield
Post Mon Nov 22, 2010 4:04 pm
Post Mon Nov 22, 2010 4:06 pm
Post Mon Nov 22, 2010 11:49 pm
Why the edit Rav? :?
whipsey
Post Tue Nov 23, 2010 9:32 am
i'd be careful using a toffee wheel on it your likely to burn through try soaking it in some type of wd40 oil and see if it gets underneath anywhere
Post Tue Nov 23, 2010 10:16 am
I've ordered some of that stuff e30topless put a link for.. :)
Ranchero
Post Tue Nov 23, 2010 10:21 am
I've used lighter fluid in the past, with good results. You need to keep soaking a rag and applying it to the sealant. It doesn't work instantly but with patience it should do the trick.
telski789
Post Sat Dec 11, 2010 10:46 am
i use a stanley blade scraper...carefully!
Jim320i
E30 Zone News / COTM Team
Post Sat Dec 11, 2010 10:49 am
Angle grinder will definately remove it. :D
Decorators window scrapper will do it but carefully like Telski said... I use them at work for careful detail when needed.
Barx325i
Post Sat Dec 11, 2010 11:06 am
paraffin flame thrower
sebring
Post Wed Feb 09, 2011 8:51 pm
I had exactly the same. Just used Silicone Sealant remover from B&Q. All off, no paint damage.
m8782538
Post Thu Feb 10, 2011 3:23 pm
bug and tar remover should work fine, take your pick AG, Chemical Guys, Megs, there are loads available.
Post Sun Feb 13, 2011 6:57 pm
Those glue remover wheels are great, as long as your working on decent paint you wont have a problem.
Unless your ham fisted of course :)
Post Sun Feb 13, 2011 9:27 pm
FFS, this is still going on??? :roll:
Jhonno, get some Solvent based cleaner, from the local Double glazing company, job done. :cool:
KEFLON
Post Mon Mar 28, 2011 11:46 pm
not sure if it will ruin the paint but white spirit will remove silicone sealant
