I know this question has probably been asked before but I can't find the answer
Can the ball joint be replaced (easily) or does the whole track control arm have to be replaced?
E36 TCA Ball Joint
You're better off replacing the whole control arm for an E30 one. They're only about 50 quid each if I remember right and are much easier to replace than going to the hassle of pressing in a new ball joint.
e30bmlover
- Ac Schnitzer prophet
E36's chew balljoints! not to mention rear axle bushes too.. put the e30 ones on!!
