E36 TCA Ball Joint
L19JGB
Post Sun Nov 21, 2010 3:22 pm
I know this question has probably been asked before but I can't find the answer
Can the ball joint be replaced (easily) or does the whole track control arm have to be replaced?
Ric_Vezza
Post Sun Nov 21, 2010 7:18 pm
Yes but you need a special tool to remove and install them.
L19JGB
Post Mon Nov 22, 2010 5:02 pm
Got a reasonable price for the ball joint, where can I beg/borrow/steal/hire the tool. Also how easy is it to swap the ball joint?
aj_mckay
Post Thu Nov 25, 2010 4:53 pm
You're better off replacing the whole control arm for an E30 one. They're only about 50 quid each if I remember right and are much easier to replace than going to the hassle of pressing in a new ball joint.
si-
Post Sun Dec 05, 2010 2:04 pm
just changed both on my e36 change the whole arm, e30 ones have better ball joints the e36 ones are mounted in rubber and that perishes the e30 are solid mounted
e30bmlover
Ac Schnitzer prophet
Post Mon Dec 06, 2010 10:45 pm
E36's chew balljoints! not to mention rear axle bushes too.. put the e30 ones on!!
