Grp A Rear suspension Pictures
spewy555
Post Fri Nov 19, 2010 8:47 pm
Has anyone got any pictures of the DTM/ Grp A rear suspension set-up?
Born to loose, live to win
Kos
Post Fri Nov 19, 2010 8:49 pm
have look on the M3 tech forum, lots of info and pics there
what exactly are you after/want to see?
Theo
Post Fri Nov 19, 2010 8:51 pm
spewy555
Post Fri Nov 19, 2010 8:54 pm
I`m just putting a build together for a semi spaceframed racecar and was hoping to see how BMW had done it at the back end so to speak!
GeoffBob
Forced Induction Specialist
Post Sat Nov 20, 2010 8:24 am
Spewy, I built my own spaceframed car that uses the front and rear E30 subrames.
I lowered the cars COG by raising the height of the points at which the E30 subframes locate to the spaceframe.
Details here if I can be of any help to you.
MarkT
Post Sat Nov 20, 2010 8:53 am
http://www.s14.net/jakesdtmtours/suspension.html
This is a really good set of pictures. I have used them for ideas/insparation throughout my build, where I have tried to replicate in part the DTM set-up. Take a look at my link in my signature. Feel free to PM me if you want to chat.
E30 340i project in progress now 328 turbo
Breaking '97 728i Auto box, tubular manifolds and other morsels.
For sale E34 M50 sump, pick up and dip stick. PM for de
UweM3
Post Sat Nov 20, 2010 9:35 am
Gee-Sport in London is able to convert your rear axle to Grp-A spec with all the rod ends, bearings, adjusters etc. Even changes the angle of the trailing arm axis to avoid camber chages when trailing arm moves up and down.
ross_jsy
Post Sun Nov 21, 2010 10:28 am
Dare I ask how much that would be Uwe? :eek:
UweM3
Post Mon Nov 22, 2010 6:27 pm
ross_jsy wrote:Dare I ask how much that would be Uwe? :eek:
let me say it like this, I you have to ask you can't afford it winkeye
It would be about a third of my cars value to give you a hint.
Check you PM.....
N00b
Post Mon Nov 22, 2010 7:54 pm
GeoffBob wrote:Spewy, I built my own spaceframed car that uses the front and rear E30 subrames.
It'd be so easy to hate you if you didn't come across as such a nice guy.
/damn your engineering knowledge and ability.
ross_jsy
Post Thu Nov 25, 2010 1:05 am
Check you PM.....
Got to say it's not as bad as I was expecting....still a hefty chunk of change though 8O some of the grpA m3 stuff goes for obscene money comparitivly though
UweM3
Post Thu Nov 25, 2010 6:14 pm
Check you PM.....
so you're saying my car isn't worth a lot? :D
I can PM you the contact number if you want to get in touch
ross_jsy
Post Sat Nov 27, 2010 1:53 pm
Haha I assure you my car is in a lot worse a state than yours (it still looks pretty much like my avatar 12 months later).
Alas, while I think it is a reasonable amount for what you get, my pocket will barely stretch to cover the phone call let alone the suspension :D
