Fuel system problem
Kilomph
I received my VDO fuel pump today, installed it, didn't work. Tested the power to the fuel pump, no power at all. Tested the relay, didn't work. Went to local junkyard and pulled two of the exact relays off of an E36 325i. Put them in, niether seemed to work. Borrowed somebody else definite working relay and tried it out, still no power. The fuse isn't blown. I jumped where the relay plugs into and the fuel pump would hum like it should, but the car would not even sputter. Does anybody have a clue as to what the problem could be? Could my motronic have failed? Any input would be much appreciated.
Kilomph
I apologize for putting it in the general forum, I meant to put it in tech help. Could an admin please move it for me?
Kilomph
My pulse sensor only had 200ohms when it should have 540 +\- 45 ohms. The bently manual says for accurate readings it should be 77F out, think my multimeter could be that off because its only 38F out?
