Fuel system problem
I received my VDO fuel pump today, installed it, didn't work. Tested the power to the fuel pump, no power at all. Tested the relay, didn't work. Went to local junkyard and pulled two of the exact relays off of an E36 325i. Put them in, niether seemed to work. Borrowed somebody else definite working relay and tried it out, still no power. The fuse isn't blown. I jumped where the relay plugs into and the fuel pump would hum like it should, but the car would not even sputter. Does anybody have a clue as to what the problem could be? Could my motronic have failed? Any input would be much appreciated.
