Can someone write me short list for m50 con please
As the m50 conversion thread is slot harder to flick through than the m52 thread can someone please write us a short list of parts and nesesary mods thsnkyou kindly
Justin
Ps is it better havin the m50 or m52 can buy a complete 325e36 but trying to hold out for a 328 cheers
Justin
Have a good ganders thru the hole M50/M52 section and you should find all the info you need.
There is no right and wrong way of doing these swaps as such,there are so many different combo`s that can be used.
Happy hunting.
Happy hunting.
yeah, fitting M52 is the same as M50 (except EWS stuff on M52)
Well that's a blessin in disguise that's the one thing I was worried about I fitted a m52 in a compact last year an it all plugged straight in so deffo goin m50 lol so I can use e34 rubber mounts mk2 golf master sylinder or is itservo and e34 sump and pick up
Not sure if its been fully answered but hey
All went into a E30 318 Touring
I used
M50 24v 2.5 Non Vanos
E34 525 M50 Sump & Oil pick up
E36 325 M50 engine arms
E34 M5 or 525 Rubber Mounts
E36 323 Exhaust Manifolds
E30 320 Ashely Exhaust system 2.5" bore, with custom downpipe
E30 318 Gearbox
E30 M20 325 Flywheel (machine lightend, stock is fine)
E30 M20 325 Clutch
E30 318 Propshaft
Solid Steering Coupling
E34 525 Rad
No vicous
Electric Fan
Golf Mk1 Gti Servo or Mk2 Servo
Stock Master Cylinder used
Custom made wiring loom adaptor
Stock engine harness and ecu
Relocated battery to boot
Believe that was everything, hope it helps
o and hey how its for sale too!
I used
E30 318 Gearbox
E30 M20 325 Clutch
E30 318 Propshaft
E34 525 Rad
No vicous
Electric Fan
cheers for that list phil. I was after the same info. I've already got the m20 clutch and flywheel. Just need the 318i gearbox and prop.
Did the engine fit ok into the engine bay with the e36 engine mounts and was the gear shift linkage ok?
- Brianmoooore
As I've posted before, apart from items 2 and 3, there isn't one part on that list that I used in my first M50 E30!bimanut wrote: There is no right and wrong way of doing these swaps as such,there are so many different combo`s that can be used.
No problem, yes it all went in fine, where abouts are you based, if your near you can always pop over and lookbarker246 wrote:cheers for that list phil. I was after the same info. I've already got the m20 clutch and flywheel. Just need the 318i gearbox and prop.
Cheers Phil,
I live 5 mins from Junction 6 on the M25 just on the Surry/Kent border. Thanks for the invite, It would be great to see how your car looks. I'm working away for a couple more weeks but could pop over november some time.
Sorry to bump up an old thread but I have a quick question about props.
In this thread it says a G240 (m40) gearbox and 318i prop can be used with an m50. I was under the impression this would be too long and that a 320i prop would be best and that a 325i e30 prop would be too short.
are all e30 props compatible with a g240 swap or am I going to run into trouble with propshaft lengths?
