m40: still cold start racing-
bigwinn
Sun Sep 26, 2010 4:13 pm
Hi all
Replaced everything now (apart from the blue temp sensor) and the engine races between 750 to 3k reva for about a minute...
Filter changed
Fuel pipes changed
Air filter changed
Vaccum pipes checked
So.... is it the blue temp sensor???
Or am I missing something?
And on a similar note, now I've found the damn sensor (cheers Daimlerman) how the hell do you change it? Do I need to remove anything to get access?
Stu
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
bigwinn
Sun Sep 26, 2010 5:46 pm
or should I just get a new AFM?
bigwinn
Sun Sep 26, 2010 8:35 pm
anyone...? :roll:
Banjo1981
Mon Sep 27, 2010 8:58 am
IF you're brave you could probably get a socket on a longe extension bar over the top of it once you've removed the plug iirc it's a 17mm nut. Basically it's a screw out, screw in job but you might have to drain the the head of coolent first. (not 100% on that though)
If you're not feeling brave you'll have to pull the top hal of the inlet manifold off to make it easy access.
bigwinn
Mon Sep 27, 2010 10:27 am
bugger.... need to grow a pair
Mon Sep 27, 2010 2:12 pm
To change the blue temp sensor on a M40, first remove the AFM/air meter then remove the black frame that supports everything under the manifold. It supports the fuel pipes, wiring box, etc.
Leave everything in place that's attached to it, just hanging.
You should be able to then push your way through to the temp sensor.
bigwinn
Mon Sep 27, 2010 2:26 pm
cheers Brian, do you think that this is teh likely cause now that I've changed everything else?
S
greg124
Tue Sep 28, 2010 12:43 pm
Mine was revving between about 750 and 1200 for about 30 seconds on cold mornings. Changed the blue sensor and it didn't make the sightest bit of difference.
If you do find the cause I'd love to know
bigwinn
Tue Sep 28, 2010 1:12 pm
oh great
if its not that may change the coil
