old rubber seals
d1mkaz
Post Fri Aug 27, 2010 8:36 am
some seals look old and hard, particulary cabrio hood seals, did anyone tried rubber renewing products, any advices, after searching in-net found this:
http://www.zymol.com/zymolseal85oz.aspx
is this good? may be something else?
e30den
Post Fri Aug 27, 2010 8:01 pm
Zymol don't make crap products, but cannot perform miracles on knackered old seals :)
powelly
Post Thu Sep 02, 2010 2:38 pm
Nothing is going to make a knackeres seal perfect again, Zymol Seal is a very good product but pricey, I use Einszett Gummi Pflege on mine and customers cars, you should clean the seals with all purpose cleaner before application though.
http://www.shinearama.co.uk/product.php ... -GUMMI-100
Image Le Mans Classic 2006
d1mkaz
Post Thu Sep 02, 2010 4:43 pm
powelly wrote:Nothing is going to make a knackeres seal perfect again, Zymol Seal is a very good product but pricey, I use Einszett Gummi Pflege on mine and customers cars, you should clean the seals with all purpose cleaner before application though.
thanks
after little research decided to change all seals... and look after them a bit more :)
DaveD
E30Zone Wiki Specialist
Post Thu Sep 02, 2010 6:41 pm
try silicone grease
Bluto
Post Sun Sep 05, 2010 2:31 pm
seal feed by swissvax, not the cheapest but (did) a really good job on mine.
