some seals look old and hard, particulary cabrio hood seals, did anyone tried rubber renewing products, any advices, after searching in-net found this:
http://www.zymol.com/zymolseal85oz.aspx
is this good? may be something else?
old rubber seals
e30den
Zymol don't make crap products, but cannot perform miracles on knackered old seals
powelly
Nothing is going to make a knackeres seal perfect again, Zymol Seal is a very good product but pricey, I use Einszett Gummi Pflege on mine and customers cars, you should clean the seals with all purpose cleaner before application though.
http://www.shinearama.co.uk/product.php ... -GUMMI-100
Le Mans Classic 2006-
d1mkaz
thankspowelly wrote:Nothing is going to make a knackeres seal perfect again, Zymol Seal is a very good product but pricey, I use Einszett Gummi Pflege on mine and customers cars, you should clean the seals with all purpose cleaner before application though.
after little research decided to change all seals... and look after them a bit more
DaveD
- E30Zone Wiki Specialist
try silicone grease
Bluto
seal feed by swissvax, not the cheapest but (did) a really good job on mine.
