Rear speakers cabby?
Post Tue Aug 03, 2010 6:21 pm
Hi what should I be looking for in speakers so it will fit in a cabby in the rear?
mrLEE30
Post Tue Aug 03, 2010 7:37 pm
size and depth is the main issue, heard 12/13cm can fit but 10cm goes in much easier, assuming you dont want to have the grill sticking out.
i went for a 10cm Pioneer 2 way and they sounded ok - as far as such a small cheap speaker can sound ok!
PG325
Post Tue Aug 03, 2010 8:55 pm
I've fitted Alpine SXE1325s, they're 13cm and fit perfectly.
Post Tue Aug 03, 2010 11:00 pm
Depth is an important thing to take into account as there is not much space behind the doorcard. I had to make some custom speaker covers as my speakers had too much depth.
Post Tue Aug 03, 2010 11:15 pm
PG325 wrote:I've fitted Alpine SXE1325s, they're 13cm and fit perfectly.
That looks good. Only thing RMS is bit low as my amp is 4x75rms.
PG325
Post Thu Aug 05, 2010 9:58 pm
Possibly so, I'm only running straight from the Alpine head unit, plenty good enough for me.
Post Sat Aug 14, 2010 7:37 am
mrLEE30 wrote:size and depth is the main issue, heard 12/13cm can fit but 10cm goes in much easier, assuming you dont want to have the grill sticking out.
The speaker size is 13cm. Why would you want to reduce the diameter when you don't need to?
johnt0709
Post Sat Aug 14, 2010 7:54 am
I replaced mine with almost like for like pioneer dual cones fitted no problem
Phase I - Bodywork Complete
http://www.e30zone.net/modules.php?name ... by+restore
Phase II - 2.8 stroker- Complete
Project II - 325 Motorsport Cabriolet Restoration.
johnt0709
Post Sat Aug 14, 2010 8:02 am
Post Sat Aug 14, 2010 8:14 am
johnt0709 wrote:Image
That looks a good option. Whats the sound quality like?
paps78
Post Sat Aug 28, 2010 10:50 pm
hey i need to replace both the front and rear speakers in my cab, any suggestions, i.e make and model of speakers. running direct of an alpine head unit. heard pioneers are good for bass? any recommendations greatly received.
chrisbmwe30
Post Sun Aug 29, 2010 12:20 pm
first things first how much you looking at spending ??
ive just put alpine g componts 13cm in the front and rear of my e30 cab sound mint and cost a£115 a set ??
all so running alpine 9060r head unit alpine mono 1000 watts amp and alpine x2 12 type r subs 1500 watts each. plus a power cap and 4 gauage wireing kit this sounds very loud in a cab with roof down cost me £1300 for everthing.
so you just need to set a buget mate?? 8)
mrLEE30
Post Sun Aug 29, 2010 8:40 pm
my standard ones were 10cm Nakamichi speakers, never thought to try 13 cm to be honest!
