325 non starter - fuel pump?
bpowell555
Post Thu Jul 22, 2010 9:18 pm
Have had a few rev wavers 2-3k recently. Drove from parked to the petrol station today and after I filled her up started and she died then wouldn't start.
Just off to try fuse number 11, but otherwise will open up the carpet saturday morning and check for power to the pump.
If the plugs are dry I guess that's also a sign? Anything else I can check?
Cheers!
:cry:
1990 325i touring
She's a minter! Best 3 years of my life - bye bye baby :D
Theo
Post Thu Jul 22, 2010 9:25 pm
First thing to do: bridge pins 30 & 87 of the fuel pump relay socket to see if the fuel pump runs.
bpowell555
Post Thu Jul 22, 2010 9:50 pm
Can I use a multi meter to bridge it? :?
1990 325i touring
Theo
Post Thu Jul 22, 2010 9:53 pm
No, use a bit of wire.
bpowell555
Post Thu Jul 22, 2010 10:02 pm
Well, if helps with anything, fuse 11 is good. There's no continuity between 30 and 87 with the ignition on.
There's good voltage between 85 & 86. Do I need to check power at the fuel pump?
1990 325i touring
Theo
Post Thu Jul 22, 2010 10:05 pm
Theo325 wrote:First thing to do: bridge pins 30 & 87 of the fuel pump relay socket to see if the fuel pump runs.
bpowell555
Post Thu Jul 22, 2010 10:07 pm
I'll need a helper though or I won't be able to hear it ...
1990 325i touring
Theo
Post Thu Jul 22, 2010 10:08 pm
Oh, didn't realise you were hard of hearing. :o:
bpowell555
Post Thu Jul 22, 2010 10:13 pm
So if I don't hear anything its not the relay and check the pump?
1990 325i touring
Theo
Post Thu Jul 22, 2010 10:17 pm
If you do that and the pump doesn't run it's fecked. If you can't hear it then you can remove the fuel supply hose from the fuel rail and you will be left in know doubt as to whether the pump is working or not.
bpowell555
Post Thu Jul 22, 2010 10:28 pm
The way it died was definitely a loss of fuel pressure. So either the relay or the pump or the connection to the pump is fooked. Can't do anything till saturday now...
Cheers anyway - on the plus-side if she runs better after this I'll be a happy man :D
1990 325i touring
Post Thu Jul 22, 2010 11:44 pm
