slight problem thats annoying.
hammoj28
This is starting to get on my nerves! I drive a 316i. Every so often when you are driving along the engine just dies then comes back on. Sometimes it doesnt even come back on and you have to stop and start it. Its not great when you start it in the mornings either. bit jerky when you drive off. also a strong smell of fuel. Im getting annoyed with it.
24v tech2
Geeman
try looking for a leaky air pipe... sounds like it's what it could be. Had a similar problem with my Sport a few years back...
Giles.
Giles.
hammoj28
Yeah I was thinking something to do with air. I have replaced some pipes.Obviously not the right ones though. Will have a good look.Thanks. any hints to pipes that wear or perish most? Or could it just be any one. Also would this suggest the smell of fuel aswel? My fuel pump is also going nuts. You can hear it all the time.
24v tech2
elliot
could be a bad earth somewhere n all, check the battery connections aswell dude
irish320i
trottle posistion sensor is always a good place to check cause it gets filled with crap can end up limiting your rev s really low mine would nt go over 1500 rpm
hammoj28
Hmm.Not sure what it is. cant find a leaky pipe. maybe a sensor?
24v tech2
