I am going to remove the electric aerial from the rear wing and blank off the hole. Does anybody know of an internal aerial that can be used (with or without an aerial amplifier) which can be hidden somewhere and will still pick up a decent signal?
Cheers!
Taylor.
Internal Aerial
Taylor325i
- Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
bdx
iirc Ford use the rear heated window as an antenna with an adaptor box.
steviec_lj
The E36 has an internal ariel, I believe this also uses the rear screen.
chu346
I'm sure there was a solution on another thread. I think you can buy a universal internal ariel that you can mount near the screen.
Do a search in this section.
Taylor325i
Cheers Guys.
Taylor.
Taylor.
Raj_p
My volvo uses an internal aerial in the rear screen.
In the nsx, we have got rid of the pop up aerial and fitted an amplified one from maplins, which you can mount in the rear (or front) screen, and works great.
Only real men get it done with an M20
Razza
I want to do this too, surely someones done it?
Raj_p
I have as said above, but just not in the e30, it works really well.Razza wrote:I want to do this too, surely someones done it?
Raj_p
Mines like this:
http://www.rockshore.uk.com/windscreen- ... -483-p.asp
I've fitted it in the rear window at the bottom
