Internal Aerial
Taylor325i
Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Sun Jun 27, 2010 12:05 pm
I am going to remove the electric aerial from the rear wing and blank off the hole. Does anybody know of an internal aerial that can be used (with or without an aerial amplifier) which can be hidden somewhere and will still pick up a decent signal?
Cheers!
Taylor.
bdx
Sun Jun 27, 2010 3:47 pm
iirc Ford use the rear heated window as an antenna with an adaptor box.
steviec_lj
Sun Jun 27, 2010 4:40 pm
The E36 has an internal ariel, I believe this also uses the rear screen.
chu346
Sun Jun 27, 2010 5:19 pm
I'm sure there was a solution on another thread. I think you can buy a universal internal ariel that you can mount near the screen.
Do a search in this section.
Taylor325i
Sun Jun 27, 2010 10:24 pm
Cheers Guys. :thumb:
Taylor.
Raj_p
Sun Jun 27, 2010 10:32 pm
My volvo uses an internal aerial in the rear screen.
In the nsx, we have got rid of the pop up aerial and fitted an amplified one from maplins, which you can mount in the rear (or front) screen, and works great.
Only real men get it done with an M20
Razza
Mon Jun 28, 2010 10:55 pm
I want to do this too, surely someones done it?
Raj_p
Mon Jun 28, 2010 10:57 pm
Razza wrote:I want to do this too, surely someones done it?
I have as said above, but just not in the e30, it works really well.
Raj_p
Mon Jun 28, 2010 11:00 pm
Mines like this:
http://www.rockshore.uk.com/windscreen- ... -483-p.asp
I've fitted it in the rear window at the bottom
