So my engine build will be complete soon and I am in need of some injectors... I read about some injectors being a higher impedance and only suitable for certain cars...
Whats this about?
My car is a pre facelift but I will be doing the motronic upgrade (supplied by SPADGE) so what type of injectors should I be getting... Its a 2.7 with all the good bits..
Can someone give a example of a injector on ebay or something?
Mike
Whats injectors do I need?
- Brianmoooore
Impedance = resistance measured with alternating current.
ok, apparently the sketch is that if your on a good 2.7 than fully rebuilt 2.5 injectors are more than adequate. anything else needs an eprom or a map that knows about them and compensates for them. i used to use the M50B20 injectors and i personally felt it to be a smoother rev band. but i am nearing my 2.7 and been told its a super no no.
M30B35 etc injectors with the AFM and a lambda also are apparently not worth it.... so i have been told...
- AlpineAde
Mike, the stock E30 325i injectors are 14.5 lb/hr. They are high impedance.
The part number is 0-280-150-715.
If you want to go a step up then the 0-280-150-714 injectors are a direct bolt in part and will be fine on Motronic 1.3. They flow at just over 18 lb/hr an will give you loads of head room. You will need to map for them, though, to get benefits. The 715s will work 100% right out of the box with the management you plan to use.
This site will give you all the tech info you will need:
http://users.erols.com/srweiss/tableifc.htm
