do you think all older cars lose bhp over the years?
Just had my H reg 325i touring on a dyno run and is still 167bhp... no engine mods at all,not bad i think?
bhp loss over the years?
Some seem to loose quite a bit of power and some don't loose any at all.Had my 318iS on the dyno last year when it was totally standard and it made 138bhp,so actually gained some
.It is mostly to do with how the car is minded I suppose.
- Brianmoooore
HP drop off is for 'other makes'. Any E30 engine should produce all its horses, providing the injectors are working properly, assuming adequate servicing and maintenance.
25 years and 240k miles on the clock and mines still doing extreamly well and feels very lively off the line and when going in the torque band in 3rd and 4th !
Felix79 aka Dan
E85 Z4M Roadster
E85 Z4M Roadster
How do you test if the injectors are OK?Brianmoooore wrote:HP drop off is for 'other makes'. Any E30 engine should produce all its horses, providing the injectors are working properly, assuming adequate servicing and maintenance.
Most injector cleaning shops can measure the flow rate and operation of the injectors however once you've removed them and taken them to the injector cleaning place you might as well have them cleaned and rebuilt.Blitz wrote:How do you test if the injectors are OK?Brianmoooore wrote:HP drop off is for 'other makes'. Any E30 engine should produce all its horses, providing the injectors are working properly, assuming adequate servicing and maintenance.
gaszman
- E30 Zone Meets/Events Team
my sport with 194000 on the clock has lost a little i had mine dyno and got 168bhp so i thought that was good.
#was expecting to walk home but she turned out really good
Jesus325iTouring
- Frog freak !
New engine has 168bhp though so all is happy in my driveway.
