m50 info please
Baz666
Post Sun May 02, 2010 12:49 pm
is there some one on here who will do the wiring loom for the m50 conversion as i`m starting from fresh and dont have a clue what i`m doing.
Post Sun May 02, 2010 12:57 pm
DanThe is your man
PM him and he'll sort you with a plug n pay loom. The looms vary a little depending on whether the car is vanos or non-vanos. Also, any loom he does he extends so that the ECU sits in the proper place under the dash. E34 looms aren't as long so you end up with the ECU sat near the battery unless yo extend them.
He can also do you a loom for the electric fan setup so that it all works as it should.
The engine looms are exchange, so he'll need your loom from your donor car. If he has some in stock he'll send you one straight away, but it not he'll need to modify your own loom.
Post Sun May 02, 2010 12:58 pm
My E34 loom sat under the dash ok.. :?
Post Sun May 02, 2010 1:02 pm
Actually Dan, I have probably got them the wrong way around, maybe E36 is the shorter one? :mad: :P
This is why I pay someone to give me the right bit to fit :)
stup86
Post Sun May 02, 2010 1:03 pm
I hope the E34 is longer, that's what I have!
Parts needed:
M40/M20 ignition coil with high voltage lead
Baz666
Post Sun May 02, 2010 1:09 pm
the m50 i`m looking at at the mo has a fan on it built in like the m20`s when i spoke to the person he didn`t know wether it had vanos or not he didn`t have a clue like me how do you tell.
stup86
Post Sun May 02, 2010 1:29 pm
Baz666 wrote:the m50 i`m looking at at the mo has a fan on it built in like the m20`s when i spoke to the person he didn`t know wether it had vanos or not he didn`t have a clue like me how do you tell.
That built-in fan is a viscous fan, and from what I've been told, it sticks out too far to fit in the bay (correct me someone if I'm wrong)
Front of a vanos engine has a bulge as shown below:
Hope that helps,
Stu
Parts needed:
Post Sun May 02, 2010 1:30 pm
Yeah, but Barry.. You need to remove it
mr_dink
Post Sun May 02, 2010 1:32 pm
You'll need to remove the viscous fan and fit an electric one.
A vanos engine has a sticky outie bit on the front of the head which is the vanos unit, this is non-vanos -
This is with vanos -
Cook318IS
Jhonno wrote:My E34 loom sat under the dash ok.. :?
the e36 loom is the longer one but if unravel all of an e34 loom it will just about stretch to the e30 ecu location (aparently!)
mr_dink
damn too slow!!!!!!!!!!!
stup86
Post Sun May 02, 2010 1:34 pm
mr_dink wrote:damn too slow!!!!!!!!!!!
:P
Parts needed:
Post Sun May 02, 2010 1:41 pm
Barry, I would recommend going for a vanos version as the non-vanos stuff really needs to be worked (think of it as an M42 with a couple of extra cylinders).
Are you looking at the one that is for sale on here at the mo in Birmingham? That is a non-vanos lump and can't be original to the donor car as the dude is saying it is in a 1994 E36, I'm pretty sure by '94 all M50 stuff was vanos but I may be wrong.
If I am correct, then if the bandits that swapped in the engine in the E36 originally did not swap loom and ECU then it won't be running 100%.
I'm not trying to shat on someone's for sale goodies any more than I'm trying to avoid someone buying a box of bits if you know what I mean, just trying to save someone grief in the long run by needing to source more bits.
You'll need E34 sump, dipstick and oil pick up pipe before an E36 M50 will drop into an E30.
Post Sun May 02, 2010 1:51 pm
Non VANOS was 91/92
Baz666
Post Sun May 02, 2010 2:53 pm
Thanks guys this is the one i have just brought i think its a sigal vanos unit 120 miles been very well service comes with all ancilleries ecu and loom.
pick it up one day in the week :D what else have i got get i know about the e34 sump and dip stick but what else do i need to get.
what e34 sump do i need from what engine,??
Post Sun May 02, 2010 2:55 pm
Is that the one off eBay? Had a quick look at it this morning and thought it looked a good buy, £120 IIRC?
Baz666
Post Sun May 02, 2010 2:59 pm
yeah dude spoke to him and he said it`s a dame good engine he has all paper work and history on it so i thought fook it buy it you fool so i did.
Cook318IS
£120!? Bargin!
Post Sun May 02, 2010 3:04 pm
I nearly bought it for spares, if it hadnt been so far away I would have done :D
Baz666
Post Sun May 02, 2010 3:08 pm
it`s only about 30 miles from me.
could i not use another rad and use the fan thats already on it ???
Post Sun May 02, 2010 4:21 pm
get rid of the viscous mate, it's too close for comfort and a heavy stab on the brakes could have it eating into the rad.
You'll be needing some 2.8 M52 exhaust manifolds, a clio servo and E28 M5 engine mounts (rubbers)
Baz666
Post Sun May 02, 2010 4:33 pm
thanks mr team member your a star i better start spending some more money then :roll:
Post Sun May 02, 2010 4:35 pm
what gearbox have you got?
Baz666
Post Sun May 02, 2010 4:38 pm
i`v been told to get a 318is m42 box is this right. also which servo will i need anyone from a clio ??
stup86
Post Sun May 02, 2010 5:55 pm
The servo needs to be from a clio with plastic front wings. I think from 99 onwards but say 2000 to be safe.
I just got my servo last week and got the same one as Cook318is, the part number is 77 00416626/C
Can an M40 box be used? If so I have one in the garage if you're interested.
Parts needed:
Cook318IS
Post Sun May 02, 2010 5:57 pm
Baz666 wrote:i`v been told to get a 318is m42 box is this right. also which servo will i need anyone from a clio ??
Theres no right or wrong gearbox to use. I used an m40 gearbox with my m50, but im using the e36 328i gearbox with the m52. You can use an m20 gearbox but you need to modify the gearbox crossmember.
the "plastic winged" clio (about 2000-01 iirc) is the servo that you want. Its the preferred option over the golf servo people used to use.
Baz666
Post Sun May 02, 2010 6:02 pm
i`v been looking into the clio servo there the same servo from 98-01 so just got one of them :D as for the box i might aswell use mine then yeah do you know how it has to be modifyed.
it has the part number on 77 00416264/c would that be any different to your 77 00416626/c
also wheres the best place and price to get the engine mounts from.
stup86
Post Mon May 03, 2010 8:17 am
Baz666 wrote:also wheres the best place and price to get the engine mounts from.
Rubber mounts or alloy mounting arms?
I got my rubber mounts from Jhonno off here, so just got lucky with that.
As for the alloy mounting arms, I got them from a scrapyard for £10.
Parts needed:
Baz666
Post Mon May 03, 2010 9:58 am
Thanks stup86 the engine mounts and the wiring loom done is all i need now
got the engine, clio servo, m52 manifold :D
also can anyone do this for me i can send out the bracket.
town325i
Post Mon May 03, 2010 10:22 am
Baz666 wrote:Thanks stup86 the engine mounts and the wiring loom done is all i need now
The m20 gearbox is a waste of time if you ask me get an IS gearbox it fits propery without bodging anything up
Post Mon May 03, 2010 1:15 pm
+1
325i prop, 320 gear linkage bits and a standard E30 gearbox support.
M20 box will be on the tilt, iS box sits straight
Baz666
Post Mon May 03, 2010 1:38 pm
sorted Dan just got one 1991 e30 m42 box :cool:
also Town he said he might drop it of at pentalvers for me, but as you know the place already it might be easyer if you do it i`ll let you know.
Baz666
Post Mon May 03, 2010 4:12 pm
Which clutch do i need to get i`m not bothered about name brands or anything to expensive.
town325i
Post Mon May 03, 2010 4:24 pm
what are you planning to use an m20 clutch and flywheel or you planning on using an m50 clutch and flywheel?
Post Mon May 03, 2010 4:27 pm
If you want to use M50 flywheel, clutch & starter I have the lot here, clutch looks very good.
Obviously the dual mass flywheel weighs a tonne, but I would post this lot to you for £30
You are better off with M20 flywheel & clutch though
