electric windows only work with passengers door open
elliott
Sat Apr 03, 2010 1:13 pm
hi all can anyone help me please, as above really my windows will only work with my passenger door open!!?
gooner1
Out humping Reindeer
Sat Apr 03, 2010 1:16 pm
elliott
Sat Apr 03, 2010 1:56 pm
just checked fuses and there all fine, im baffled!!
Sat Apr 03, 2010 2:11 pm
Under what circumstances are the lights in the switches lit up?
elliott
Sat Apr 03, 2010 2:47 pm
just been out and checked and only when the passenger door is opened, but not when the ignition is on!!
doyley123
Sat Apr 03, 2010 6:20 pm
i would maybe think of checking the wiring in the door.
Sat Apr 03, 2010 6:55 pm
Patience! Anyone been messing around behind the glovebox area? Either a plug has become disconnected there or fuse 17 is blown.
There is a blue relay behind the glovebox which switches the power feed for the roof and windows when a front door is opened from an ignition switched feed from fuse 21 to a permanent live feed from fuse 28. This relay should operate(click) whenever a front door is opened, so if it only works with the passenger door you have a second fault, probably with the pin switch in the driver's door hinge pillar.
elliott
Sun Apr 04, 2010 2:35 pm
nobody has been near the glove box and no work has been done recently that could relate to a problem, checked fuse 17 and checked the relay plug and wires both are fine, also just had both door pins out cleaned up electrical connectors and and the contacts on the plug ends and all seems fine, should i be checking for power anywhere and if so what for? thanks.
davpkav
Sun Apr 04, 2010 2:56 pm
Might be just a trapped wire that is released when you open the door. Check the wires are running free?
Sun Apr 04, 2010 9:10 pm
You should be checking for ignition switched power on the white/black wire plugged into the accessories socket, that goes to the blue relay.
elliott
Mon Apr 05, 2010 12:08 pm
just checked and i have no switched live at the black/white wire for the blue relay, also going beck to the secondary fault at the drivers door pin this seems to be working fine as its turning the interior lights on, i can hear a reley clicking down behind the speaker on the drivers side when the pin is operated is this correct!?
Mon Apr 05, 2010 1:52 pm
The relay should click when the first of either front doors is opened.
Pull out relay K5 in the fusebox, identify pins 30 and 87 of the socket, and link them together with a piece of wire. Try the windows again. (Ignition won't need to be on.)
Howler
Sat Apr 10, 2010 12:10 am
Hi, i Have the SAME problem! Windows only work when drivers door opens, i hear Relay 'click', but this is same if ignition on Or off.
Is there an Earth fault going on here?
Howler.
Sat Apr 10, 2010 12:18 am
Relay should click when you open a front door, whether or not the ignition is on. If it only clicks when you open the driver's door, the pin switch in the passenger door pillar probably needs attention.
