Will widening the track have a noticeable increase in handling performance. I realise the M3 is about 20mm or so wider and is obviously an improvement is going beyond this beneficial?
Also how is the track widened on the E30 M3's? Therough wider suspension components or through width of tyres?
Wider track E30
MarkT
E30 340i project in progress now 328 turbo
Breaking '97 728i Auto box, tubular manifolds and other morsels.
For sale E34 M50 sump, pick up and dip stick. PM for de
FMH
Why not fit the a 5 stud conversion on the rear which will give you 20mm wider track on each side; so 40mm overall. Giving you bigger brakes, and 5 stud conversion to fit bigger/better/deeper wheels.
MarkT
I'm in the process of designing/building an adjustable rear subframe at the minute. So it would just be a case of spacing the trailing arms outwards and using some longer drive shafts.
Motorhole
Sorry to hijack this thread! But I wondered this - you can fit special offset wheels to conteract the effect of the increased track from a 5-stud conversion, but I always thought this track would be beneficial if you could roll/flare the arches to make it fit...would this be right?
FMH
Fit the wheels in accordance to the 5 stud set up. Modify the arches; not much of an issue tbh. Wider track is what you need/wantMotorhole wrote:Sorry to hijack this thread! But I wondered this - you can fit special offset wheels to conteract the effect of the increased track from a 5-stud conversion, but I always thought this track would be beneficial if you could roll/flare the arches to make it fit...would this be right?
Motorhole
Superb, thanks folks! Back to MarkT...
