Ive got a manual gearbox from an E36 1995 320i and propsaft, would this be ok to fit the s50b30 or does it HAVE to be 328 box and prop.If so whats the difference?
It is to be fitted to my E30 316.
gearbox for s50 conversion
- Homo Hair
Doesn't make a difference what e30 you are fitting it to..
I would be dubious about the clutch being up to the task. 328i boxes and props are hardly expensive..
e30mazm3
What difference is the clutch going to make to the gearbox?
You wont get a 320i box over the S50 flywheel/clutch
Nath325i
Think youll find he means putting the all the power of an S50 through a 320 clutch, might have trouble coping
Use an M20 clutch
e30mazm3
Im with you. Wouldnt attempt 286 horses through a 320 clutch!Nath325i wrote:Think youll find he means putting the all the power of an S50 through a 320 clutch, might have trouble coping
e30mazm3
So has the 328 box got a bigger bell housing than he 320. is that the difference?DanThe wrote:You wont get a 320i box over the S50 flywheel/clutch
e30mazm3
So will the propshaft be the same?
Props are different, so is 90% of the gearbox. 2.8 uses a ZF large bell housing box, most 2.0's use a Getrag box
Whats wrong with a 320i clutch? Apart from the weight issue! Im quite sure it would be fine TBH
e30mazm3
Thanks for the info danthe. that is some serious BM knowledge! RespectDanThe wrote:Props are different, so is 90% of the gearbox. 2.8 uses a ZF large bell housing box, most 2.0's use a Getrag box
