gearbox for s50 conversion
e30mazm3
Post Sun Oct 18, 2009 5:59 pm
Ive got a manual gearbox from an E36 1995 320i and propsaft, would this be ok to fit the s50b30 or does it HAVE to be 328 box and prop.If so whats the difference?
It is to be fitted to my E30 316.
Post Sun Oct 18, 2009 6:05 pm
Doesn't make a difference what e30 you are fitting it to..
I would be dubious about the clutch being up to the task. 328i boxes and props are hardly expensive..
e30mazm3
Post Sun Oct 18, 2009 6:09 pm
What difference is the clutch going to make to the gearbox?
Post Sun Oct 18, 2009 6:31 pm
You wont get a 320i box over the S50 flywheel/clutch
Nath325i
Think youll find he means putting the all the power of an S50 through a 320 clutch, might have trouble coping
Post Sun Oct 18, 2009 6:32 pm
Use an M20 clutch 8)
e30mazm3
Post Sun Oct 18, 2009 6:52 pm
Nath325i wrote:Think youll find he means putting the all the power of an S50 through a 320 clutch, might have trouble coping
Im with you. Wouldnt attempt 286 horses through a 320 clutch!
e30mazm3
Post Sun Oct 18, 2009 6:53 pm
DanThe wrote:You wont get a 320i box over the S50 flywheel/clutch
So has the 328 box got a bigger bell housing than he 320. is that the difference?
e30mazm3
Post Sun Oct 18, 2009 7:52 pm
So will the propshaft be the same?
Post Sun Oct 18, 2009 8:53 pm
Props are different, so is 90% of the gearbox. 2.8 uses a ZF large bell housing box, most 2.0's use a Getrag box
Whats wrong with a 320i clutch? Apart from the weight issue! Im quite sure it would be fine TBH
e30mazm3
Post Sun Oct 18, 2009 9:20 pm
DanThe wrote:Props are different, so is 90% of the gearbox. 2.8 uses a ZF large bell housing box, most 2.0's use a Getrag box
Thanks for the info danthe. that is some serious BM knowledge! Respect
