Removal of ABS unit
moggy
Post Tue Sep 29, 2009 2:32 pm
Is the above easy to do?
The unit looks quite heavy and therefore looks like some weight could be saved (abs doesn't work anyway).
I guess just swap over for a standard cylinder or am I being too simplistic?
UweM3
Post Tue Sep 29, 2009 2:41 pm
it's no big deal. but you should remove all the wiring to make the most of the weight saving. It is a LOT of wires.
Are you 100% sure about this? I had mine removed and still regret it a little. All the troubleshooting done?
moggy
Post Tue Sep 29, 2009 2:46 pm
The ABS doesn't work. I've never felt an issue with braking.
UweM3
Post Tue Sep 29, 2009 8:18 pm
moggy wrote:The ABS doesn't work. I've never felt an issue with braking.
I don't really need it either, but it's nice to know that there is a bit of safety for the "oh shit" moments when you come across something out of your control.
GuyM
Post Tue Oct 06, 2009 5:06 pm
i've been looking at doing this too since my abs has been disconnected for years.
i understand there is a blanking plate under the existing cylinder and you can run off that.
would be really helpful if someone who has done this could post up some instructions or link to a thread detailing how it was done...
moggy
Post Tue Oct 06, 2009 11:48 pm
I'd second that.
shorty73
Post Thu Oct 08, 2009 12:45 pm
I've done it but I've also used a larger M/C. Saves a fair bit of weight.
I've got some photos somewhere.
I will probably be fitting a pedal box in the near future so my larger M/C will be up for grabs.
See us in www.racingsaloons.co.uk helped by,
alloyproducts for alloy fabrications
www.motorsportoils.co.uk for Lucas oil
www.zeroexhausts.co.uk for the noise
MTech 07831831846 for an engine!
